Add-a-leaf
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Dec 5, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i was wondering, has anyone run add-a-leafs?
    how do you like them? how does it ride? other than the obvious "rough" how much rougher?
    im almost 97% sure i am gonna add them to all four sets of leafs
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have them in the rear but dont notice them.
    In the front , i think it would make the ride pretty stiff.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Depending on how much lift you need you could go with the ORD 1" add a leaf that would not compromise the ride a bit. There is a write up on them on the main page.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I used to have an add a leaf 2.5" lift and it rode pretty rough, and in the year and a half it was on there, it sagged an inch on the passenger side.
    90K5
  5. CK5
    May 19, 1999
    21,626
    702
    CO
    I run the 1" ORD add-a-leafs that are 0 rate, they are relly blocks that are part of the spring pack so it is like a spring that is cut down. Steve Watson at ORD says they can be used in the front also. If you want more than 1" you might think about a 2.5+" spring.
    Steve
    1990 K5 with stuff
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I am running a 2.5 inch lift (Procomp springs in front) Blocks in rear, and to raise my saggy rear I added a add-a-leaf. It has been on for about 2 years and I did not notice any thing different about the rear when I was driving it.
    If it ain't a Chevy, don't raise it up!
  7. EODBRIAN
    EODBRIAN Registered Member
    Feb 19, 2000
    82
    Indiana
    kinda curious as to why you want to run add-a-leafs all the way around?? i run them in the rear to correct my saggy butt with a 2.5" lift (it only sagged about an inch). no suspension change as far as stiffness goes.
    EODBRIAN
  8. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    i want to add 1 inch lift to my blazer but i dont want to buy new suspension because i have a 2 in sus lift now.
    and i do not liek body lifts and also i like my truck to ride rough.
    thats the most part.
    i have leafs all around.. no springs
  9. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Add-a-leaves for the rear is fine.
    I wouldn't put them up front - it may be a truck, but it doesn't have to be a portable lithotriptor.
    I don't like body lifts either, but I could easily see doing the ORD 1" body lift.
    -- Mike
  10. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    i must say i dont know what a litropater thingy is!! hehehe
    plus my blazer a previous owner put this super soft suspension on it cause he had dropped it also and i dont like it this soft, so its unusualy soft ride.
    as where i like to ride rough
