Add-a-leafs X2
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HD, Jan 20, 2004.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    Okay how bad would it be to have 2 add-a-leafs in my rear springs? The reason that I want to do this is to level my rig. Right now the front is higher than the rear, and I have the add-a-leafs just taking up space in my garage. Let me know what you think, thanks. /forums/images/graemlins/ears.gif
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    It will get stiffer with less flex. I did a 2" add a leaf in my wifes blazer. all she did was complain it was to stiff.
  3. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    Maybe I'll do some kind of shackle flip, just enought to make it level.
  4. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    how about a set of zero rates. Pretty easy to install and relatively cheap.
  5. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I think the lowest shackle flip is 2 1/2". Will give you a little more flex too! Is the truck all stock? or is there a lift in it now?
  6. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    No it is not stock. I have a add-a-leaf in the front and rear and run 35" tires. The problem that I'm trying to fix is to bring my rear level with my front. I am happy with how tall my front is but not the rear.
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    How much do you need to level? if you only need an inch, i'de go zero rate. If you want more, go shackle flip. If you do any off roading, you will want to avoid blocks.
    If you have an add a leaf in the back now, I don't think you can stack another and gain much. just stiffer.
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    What part of CA are you in?? The spring is here and summer is close take off the top and that will bring up the rear a little. Seriously though, I would try a zero rate cause it will be the easiest.
  9. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I live in the Mojave Desert in a small town called Ridgecrest. In fact I just put my top back on, did not change my ride height at all.
