Add-a-leafs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hathaway, Apr 3, 2001.
  1. Hathaway
    Hathaway 1/2 ton status
    Jan 2, 2001
    295
    Missoula Montana
    I'm planning to go up to 33's later this summer and I don't really want a lift. But I figure I could do add-a-leafs front and rear and get at least a little more clearance. I don't need to worry about changing anything like pitman arms or anything with the add-a-leafs do I? I don't want to deal with anything like that I just want a bit more clearance.
    Dan, '86 K5, 5.0L v8, NP208, TH700R4, open 10bolts front and rear, 3.43gearing, K&N filter, 31x10.50R15 Trailhandlers
  2. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    with a add a leaf you shouldnt have to do anything but put them in
    Bandit
    (Your right i dont understand the jeep thing)
  3. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    i have a six inch lift i built on just add-a-leafs i started off with a 4inch lift i got the leaf for a jeep and threw it on to give me 4 inches then i got one from a 93 ford bronco fliped it 180 degrees and to make a six inch as long as your add-a-leaf isnt bigger than 4 inches youll be fine
    NOT ALL HISPANICS DRIVE LOW RIDERS :-) <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  4. Hathaway
    Jan 2, 2001
    295
    Missoula Montana
    I'm just looking at the 2.5" Pro-Comp add-a-leafs. I don't have any lift or anything. And I've seen that 33's can fit with no lift, but I figure adding 2.5" with add-a-leafs couldn't hurt. But I only want to do it if it won't affect drive line angles and stuff. If it does I'll just do 33's with no lift at all.
