Add a leafs
Discussion in 'The Garage' started by blazerpro79, Feb 27, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    if i bought an 8" spring and put a 2" addaleaf it would make 10"s right? the only reason im asking is because i bought 2" add a leafs awhile back and just bought 8" springs from tough country. it doesnt look like those will help, looks like they were designd for stock springs?thanks for the help
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    8" springs are pretty stiff as it is depending on the spring rate , I dont think a 2" AAL wouldnt give you the result yer looking for. If you were putting them on a stock - 4" spring I would say yeh most likely but not wiht an 8" spring. I'm sure someone here has done something similar so hopefully someone else can chime in.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Don't take my advise too seriously but I don't think they will help because I would bet those 8" springs have almost as much arch to them as the addaleaf. IIRC my add a leaf was all that more arched than my stock rear springs when I put it in.
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Yep, all add-a-leafs do is add arch to your stock spring. If you have an 8" lift spring it's already beyond the arch of a 2" AAL.
  5. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    well will it make the trucks load capacity stronger, so that it will not take any droop from the shell?
  6. AkMudr
    Dec 30, 2004
    917
    Alaska
    Personally I think using an AAL would be worthless, like already stated the arch of an AAL is less than the arch of an 8" spring. An AAL would be useless in that type of situation.
    One option is to have the sprigns slightly arched.
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    it will act like an overload if anything. you'll need to compress that 8" spring quite a ways before it comes into contact w/ the add a leaf.
