add-a-leafs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Jun 23, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    can you put add-a-leafs on the front springs...I did a search and came upwith no helping results....can any one else help me........................................Ryan
    high
  2. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
    Well you werent looking very good, just about everyone makes them for a Chevy. Got 4wheelparts.com,, thats four wheel parts wholesalers site,, they'll have what ya want,, if its not online, they have it in a catalog,, I know, I got one, and there in there,,or you might have a Four Wheel Parts Wholesalers near you,,
    Never been stuck, just temporarily delayed.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yes you can...They stiffen the ride,but they do work!
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  4. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    i wasn't talking about a web search, i was talkingabout a post search on this site wether or not you can use them.............................Ryan
    high
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    try these from ORD... most here recommend staying away from 4wheelparts unless you can walk in one of their stores. they don't affect ride quaility either like an add a leaf would.
    <A target="_blank" HREF=http://www.coloradok5.com/ordaddaleafreview.shtml>http://www.coloradok5.com/ordaddaleafreview.shtml</A>
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  6. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Hi Ryan,
    just about any spring shop should be able to help you out but keep in mind that this method of lifting your truck will result in a much stiffer ride. This is great if you use your rig as a cafe racer but pure hell on your kidneys not to mention the squeeks and rattles it will induce from wheeling and driving through potholes on city streets. A loud stereo helps but in the end, drop the bucks and do it right.
    Shawnboy.
  7. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    e only reson that i was going to do it was to put 33's on it, in about 6-8 months i was going to put a 4 inch rough country on it with front and rearsprings..................................Ryan
    high
  8. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    The ORD "add-a-leafs" are 0 rate and are not supposed to affect ride quality from what I understand, they result in 1"of lift.
  9. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    i look ed on their web site and couldn't find them.....how much are they?...............................Ryan
    high
  10. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    I think Mikey has them, you might want to pm him. His user name is Captcrunch. I think they are like $30, but I dont know for sure
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used a pair from JC Whitney. They did not make the ride that much stiffer than stock with 3 leaf springs. It's not all that bad. I added a 3" block in the back and it sat about 1/2" lower in the front. Well worth the $70 I spent until I bought the 4" Rancho.
    Tim
  12. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    WHyy not skip the 4" lift and go right for the 6"? You know you'll probably end up wanting it a little higher anyway.
    I personally think 6" is just about perfect for a chevy. 4" is too short for my taste.
    -- Mike
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wanted a 6" but everyone said on a shortbox it would throw too many driveshafts.
    Now I wish I'd gone 6" but I need a CV shaft. I might go 8" with a 4" shackle flip and 8" front springs.
    Tim
  14. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Tim, I installed my 6" lift originally on my 76 k10 shortbox. I did not lower my tcase at all. I had a 465/205 and d44/12bolt. Stock driveshafts were adequate (I do not have rocks here. I run through the mud and trails.) What I did have to do was clearance the front CV with my die grinder. Not that big of a deal.
    Now that 8" is a different story. [​IMG]
    -- Mike
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well, I wish I'd known that before. I don't know what I want to do now. I want my truck bigger. Maybe 6" and 3". But I've also got a different trans and transfer than you. I've got a 700R4/NP 208.
    Tim
