add a leafs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, Apr 7, 2002.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    I recently put on 33x12.5. I trimmed the fender just enough to make them clear when I turn from lock to lock. I still need more clearance so I was thinking of running add-a-leafs. I know procomp, rough country, tuff country, and Skyjacker all make them, but which is the best. Is anyone running these or know someone who is, I'm looking for the one that will give me the most lift, and hopefully a good ride, well as good as it get in a K5. Thanks for any info you might have.
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    But ORD calls them Zero Rate....<a target="_blank" href=http://www.offroaddesign.com/catalog/Zero%20Rates.htm>http://www.offroaddesign.com/catalog/Zero%20Rates.htm</a>
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If were me I would spend the money and get a 2 or 4in spring lift. But If you can only go with the add-a-leaf I don't think I would use the Pro-comp I put the long ones in mine and had to cut them down to fit right.
    Eric
  4. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I have the pro comp one's and didn't cut them they worked fine.
