add a leafs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schmuck, Feb 1, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    well ive finally come to realize that im just to broke and will be for a while to get any of the major modifications done to my truck that i wanted to do plus ive still got lots of little things that need attension like front drive shaft steering problems and probably a new flywheel but what i was wondering is i just got in a new jcwhitney catalog and they have some 2" add a leafs they are for front and rear and are a 2pac each now im still running on stock suppension with 35x 12.50s and the only clearance i realy wanted was just enough to put them on 10" rims i was planning on putting on a 4" lift in the front and shackle flip in rear and maybe a 2" or 3" body lift later if required but im broke so what i need to know is has anyone used the add a leafs? do they really lift the truck 2" front and rear? how is the ride? would i need a drop pitman arm for this? its only about 100bucks compared to about $250 for the 4" lift plus its alot less work and getting help doing work to my truck is almost imposible
  2. schmuck
    Nov 11, 2002
    523
    did a search already got a little bit of info just wongering if any body had anthing else to say /forums/images/graemlins/ears.gif
  3. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Ive got add-a-leaves on the back of mine and dont like them.
    As you can see they allow absolutlely no rear flex. If your just going to level it out its fine. And they ride rather stiff.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have an add-a-leaf in my rear spring packs and I hate them. Very stiff.
    However, they are cheap and do what they say. If you are strapped for cash, they are a good thing.
    Mine raised mine about 1.5" I think.
    -- Mike
  5. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Save your money. You will be very unhappy the ride will
    be real rough and no flex do to it being stiff.
    Hope this helps,
    Bo
    /forums/images/graemlins/thumb.gif
  6. schmuck
    Nov 11, 2002
    523
    well i only mud ride and the truck already rides like a brick thanks to a set of rancho 5000's and a set of helper springs im prety content with the way the truck sits now but i think a few more inches would be nice this is my daily driver so i was never planning on going real big /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I'd do a 2" body lift before an add-a-leaf. Or do a 1" zero rate in front and a 1 1/2" block in the rear.
  8. schmuck
    Nov 11, 2002
    523
    what about the steering will i need a drop pitman arm im also looking into the ord 0 rates in conjuntion with the add a leafs to get three inches but i wont do this untill later when i have more money what do yall think
