Add a leave question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, Mar 15, 2001.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    To put on front add a leaves what do I have do? Other than get longer U bolts and so on. I mite do this on the next K5 i get. Thanx
    JD
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    If you have 3 leafs you only need to remove the bottom one and install the add aleaf they work ok but stiffer than it was I went w/a 4"lift and got rid of the add a leaf
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  3. MudRebel350
    May 20, 2000
    324
    N.J.
    Theres 2 add a leafs for each side and since all the k5's i've had have had only 2 springs up front, stock, whats the way to install them?
    JD
    <P ID="edit"><FONT SIZE=-1>Edited by MudRebel350 on 03/15/01 06:01 PM (server time).</FONT></P>
  4. coopertwpk
    Mar 18, 2000
    478
    2 add aleafs? what are the lengths? the longer one should go on top if thiers a difference or the one with the most curve goes on top the others a support.most stock have 2 leafs but alott have 3 mine does
  5. MudRebel350
    May 20, 2000
    324
    N.J.
    I havent checked the lenghts. I got them with my last truck, which was an 88 GMC Jimmy (fullsize of course) and never did anything with them.They have been out in the garage for a while and btw the back set of springs has 6 in the pack and they are rough countrys.
    JD
