add-a-leaves
Discussion in 'The Garage' started by original balzer, Jan 6, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    my brother just got a shiney new 6" pro comp lift his old springs had 1 1/2" add a leaves my blazer has a 4" rancho lift heres my delema i love the flex and ride of my lift but woulnt mind that extra 1.5" lift anyone have any thoughs on wheather i should use the add-a-leaves or not?
    willow
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    add a leaves will make it feel like a 3/4 ton pickup...
    maybe look at a lift block?
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    DON'T use the add-a-leaves. They make your ride sooo hard and stop flex big time. Get some zero-rates from ORD or make your own. They bolt straight into the springpack, can be used front and rear and don't effect flex or ride!:grin:
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    4" lift spring and an add-a-leaf? I'm not sure you will get an 1 1/2" lift out of that.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I agree - the zero rates are great and simple to install.
