Add amp to stock system
Discussion in 'Audio' started by BPS, Mar 30, 2002.
  1. BPS
    BPS Registered Member
    Mar 24, 2001
    28
    Sooke, BC, Canada
    I want to add an amp and sub to my stock sound system.
    How do I connect the HU to the amp - as the stock system does not have a RCA output
  2. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    you can get a High level to low level converter at any local electronics store... basically it hooks up to your wiring for your speakers and converts it to a low level signal and then gives you a set of rca outputs to connect to an amp.. Hope this helps.... Also they are pretty cheap.. some of them come with crossovers and what not built into them also..
  3. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    You can also check for amps with high level inputs.
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I prefer to use a quality high to low level converter even when the amp has high level inputs as I think you get more voltage though the rcas this way ;-)
  5. BPS
    Mar 24, 2001
    28
    Sooke, BC, Canada
    Thanks for the info
