Adding 4" lift, do I need new shocks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LAZYMON, Oct 26, 2000.
  1. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    Adding 4\" lift, do I need new shocks?
    I did a search but couldn't find a definitive answer. I currently have RS500 shocks all around with no lift. My Tuff Country lift is here as well as my 35X12.5 ProComp MT's. Does Rancho have different part numbers for lifted trucks? Will my current shocks work? Do I need shock extenders? Help! It's snowing outside!
    Thanks.
    Topless73
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Re: Adding 4\" lift, do I need new shocks?
    Rancho 5112's are for the rear of the vehicle, and 5001 or 5118 are for the front. These are the Rancho part #s that were used with my recent 4" lift.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yes you will need new shocks. I just got some RS 9000s and the size is for a 2.5-4" lift. I can give you the part #s if you need them
    90K5
  4. LAZYMON
    Jul 26, 2000
    235
    Lake Tahoe
    MO MONE, MO MONEY, MO MONEY
    Part numbers are good as well as suggestions on other brands. What about shock extensions for my current shocks?
    Topless73
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    For my RS 9000s these are the PNs
    RS 9112=rear
    RS 9001=front lower
    RS 9118=front upper
    I have quad front shocks, but if you don't then you dont need the RS 9118s. The lower is the one that goes between the brackets and the upper is the one that bolts on beside the bracket and only uses one side of it. If you are getting RS 5000s then the last three numbers should be the same. They don't make the RSXs long enough for a 2.5-4" lift. I hope this helps.
    90K5
  6. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    No offense, but wait unitl you have the money to do it right or don't do it. There are other things to consider because every K5 reacts differently to lifts and bigger tires. A lot of kits say these parts are optional, but may be necessary. Extended brake lines, steering arm or drag-link, and possibly extending your drive shafts.
  7. LAZYMON
    Jul 26, 2000
    235
    Lake Tahoe
    None taken. The money is there, no kids, no house, no car payments, no girl friend and Heavenly ski pass paid for. All I have left is to spend money on the truck and rent. I've also bought the steering arm and brake lines, plus the ORD steering brace. For some reason I thought I could use my shocks I had. http://partsamerica.com has 25% off purchases so I guess I need to decide between the 5000 or 9000 series Ranchos or another brand.
    Topless73
