Adding AC - How Difficult
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Guy, Jul 21, 2000.
  1. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    I've got a 79 w/ no AC. Sure gets hot. Has any added AC? How tough is it? Can I take the parts from an old GM, or is there something new with 134a?
    79 Guy
    Owner of Two Great 4WD
    - '79 Blazer
    - '99 ML320
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I took a complete system out of an old wrecked truck and put it in my '81 stepside. It wasn't too bad. I have lots of tools for fab work and such. I also have all the a/c equipment, so it wasn't too big a project. It was definitely worth the effort here in Texas. The other thing I had at the time was cheap R12. I completely flushed the old system and put in a new dryer and orfice tube. Cutting the hole in the firewall was probably the worst part. It can be done!
    Let me know if I can help.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I've got a 70 Blazer, originally had AC, but someone took it out. Would a later model evap housing work?
  4. Michael
    1,576
    Sherman, Texas
    They tell me anything can be made to work with enuff hours and $$$$.....I don't know. You might be better off with a "street rod" type system made by Vintage Air or something similar. It's a complete system with all parts and they really work well. Try http://www.vintageair.com/vintage.htm Look in the Truck sure fit section. They have a setup for '67-'72 trucks!
  5. Balou
    Balou 1/2 ton status
    Apr 15, 2000
    207
    back to Germany
    I think about adding a bolt on system to the hard-top.
    Will look like a frigo-truck, but will work much better than
    the stock ones. Saw one which will only give 5cm (sorry 2inches) additional hight. They really boost cold air inside !!!
    Balou
    "Size DOES matter!!!", said the girl last night.
    http://www.balou.coloradok5.com
  6. 73CowBlazer
    73CowBlazer Registered Member
    Jul 25, 2000
    13
    Houston
    I have a 73 with all this hosing to control the vents. I believe they all run off the engine vacuumn? Does anyone know where to get new control panel and the little vacuum servos to make this all work again. Would love to have AC in Houston..
  7. Michael
    1,576
    Sherman, Texas
