Adding ATF to diesel fuel
Discussion in '1982-Present GM Diesel' started by josephn, Oct 16, 2001.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    What exactly does adding ATF to diesel fuel do?
    Lubricate?
    Reduce black smoke?
    Cetane boost?
    Cleans fuel system?
    Just want to know for future referance.
    Thanks.
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    All it does it help to increase the lubricity of the fuel. Non-sulphur diesel dries out seals and o-rings throughout the fuel sytem, and a quality conditioner is needed to keep things lubed up.
    I can't say for certain that ATF does the job properly. I also wonder what side-effects it could cause(ie plugged injectors). A better solution would be to run a quality diesel fuel conditioner such as Stanadyne.
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I don't know about your area ? Here where I live there is no need for a added lubricant in the fuel . Here there is enough sulfer for the pump to be lubricated .Check with some diesel shops where you live about your areas sulfur rates .I personally don't run a additive .
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    It also turns the fuel "red" and will cause you to get a ticket that is out of this world if caught. Fuel that is dyed red is labeled as farm fuel which has no road tax on it. They fine you by the gallon you have on board and it can be as high as 10 thousand buck$. Some states, such as New Mexico have a little device that detects it, kind of like a syringe they put in the tank and draw it out.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    One last item: ATF can be used to diagnoise a failing injection pump. As injection pumps get worn they (usually) have a problem making pressure. If the engine starts fine when cold, then has difficulty when hot, (and a hot day for you Death Valley boys) the fuel is just too thin for a tired pump. A quart or two added to the fuel increases the viscosity enough to bring fuel pressure up and "pop" open the injectors. Not really a fix, just helps to confirm your suspisions before you tear into the engine bay.
    Real trucks don't have spark plugs!
  6. josephn
    Nov 3, 2000
    138
    Utah
    Spiffy Thanks for the info.
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Yea....watch them people who check yer fuel!! If you get cought with red fuel..even if you can prove its ATF fluid...you still get a nice fine. I suggest Stanadyne Fuel Treament. It helps alot!!
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
