adding drivetrain length? 465/205
Discussion in 'The Garage' started by MattK, Jan 19, 2007.
  1. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    I've got a 10 spline 465/205 setup in my truck right now. im curious if there was an economical route to adding some drivetrain length. my front driveshaft is only about 27" long at rest and the CV doesn't like the angle at all. i hear grinding when the suspension unloads after going over bumps on the road.
    a blackbox (dont think its offered in 10 sp though) or doubler would be cool, but im hoping there is a little cheaper/easier way to relax the angles on my front shaft.
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Only thing I could think of would be moving the front axle forward. zero rates, 52s or 56s. That would lengthen the front shaft
  3. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah i've got 4" springs up front as well as a zero rate to move the axle forward 1.5". good idea with the 52/56's though.
  4. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    NWF offers 32spline output shafts for NP205's. You can then run a 1410 NP205 yoke(or make a flange if you want). The single 1410 joint will give way more angle than you will need. I plan on doing this as soon as i get my engine troubles worked out.
    Change this and the bearing and your ready for high angles. http://www.northwestfab.com/tcaseparts.html
  5. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    You could have the perches cut and rewelded on you axles to getrid of that bad angle.
  6. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I believe he is talking about the front shaft having a bad angle. You can't cut off the perches on a dana 60 front. Pass side perch is part of the diff. But you can cut the knuckles and rotate the axle, then reweld the knuckles.
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Actually he would need the inner knuckles turned on the axle tubes, as drivers spring perch is part of the differential housing on a 60.
    edit: im slow
  8. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    :haha: :haha:
  9. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    hmmm ill have to measure angles and see where im at with those.
  10. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    you could try finding a 32 spline 465/205. they are longer than the 10 spline versions.
  11. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    If your are finding a different 205, how about a divorced 205 and 2wd sm465.
  12. BoondocK5
    May 13, 2006
    10,035
    63
    I had to do both, have the diff mount ground off and had a pearch welded and heat treated, welded back onto it at the correct position then had both inner knuckles cut off and rewelded at the correct position to correct the caster angle. costed about 4 bills when I had the axle built.
  13. goldwing2000
    goldwing2000 Guest
    Switching to a 1410 driveline definitely seems to be the easiest choice so far.
    Alternately, maybe you could buy a clocking ring and rotate the case down. Those run less than $200.
  14. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Unfortunately, I dont think there is an easy way. I tried running my stock front shaft (ears ground, spicer joints) and had nothing but problems. No where near enough angle capability and it spit out joints left and right. I'm afraid it's time to spend some dough with Jesse.:D
  15. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    had the same problem with my sm465/205 combo. unfortunatley the motor in that truck had to be used in another one so I can drive it. when I get a motor for the sm465 Im gonna use some 52s to move the axle foward and get it as low to the ground as possible so that the angles arent too bad and once I get the money it will get a doubler and that should clear up my problems with the super short front shaft.
  16. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Switching to a 32spline output and running a 1410 at the case and axle would be much more cost effective, will put out give or take the same amounts as your HAD 42* cv.
  17. goldwing2000
    goldwing2000 Guest
  18. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Just get rid of the front shaft and be cool like your buddy DE.:doah: Rockwells would give you a beter angle.:eek1: :eek1:
  19. koldsimer
    Jan 10, 2005
    1,480
    texas
    :haha: :haha: :haha: Yup, I bet that would fix it.
  20. 1986K10
    1986K10 Registered Member
    Oct 21, 2006
    16
    Ontario, Canada
    As stated above, simply cutting and turning the knuckles won't change the pinion angle, you still have to move the spring pads.
