Adding fluid capacity to hydro assist steering
Discussion in 'The Garage' started by 55Willy, Nov 23, 2005.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Would there be any down side to adding a cooler and or a filter set up to a regualr system that has the longer tube to the res.?
    I'm looking at just adding a longer tube to the filler/dipstick and then maybe a filter kit.
  2. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Should be just fine. I would think it would help it run cooler too.
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have run a rail type tube fin cooler and the longer rubber hose tube for extra capicity for a while with no issues. I also just added a one of these filters a couple months ago. I think a filter is a must. Especially with the WTO setup with the older style ram...
    The filter was $12.99 + Shipping from Northerntool.com. Local farm stores also carry them.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Use a tube type cooler instead of the stacked plate type as apparently they're easier to bleed. If you find a '91 or there abouts K5 with tow pack at a junk yard they have a tube cooler under the rad.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you go to the BBC's remote res type pump body you can make or find any size reservoir that you want.
    A friend cut the cap 'bung' off one of his spare 'canned ham' pump bodies and found a piece of hydro oil compatible hose. Hoser clamped the bung in one end and clamped the hose down over the original bung. Didn't add a lot of fluid, but it got the cap up higher.
    I see the filter as a good thing and the cooler as mandatory with hydro assist.
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    Shouldn't be a problem using both a cooler and a filter + the radiator hose filler neck trick. Steering boxes can make crazy heat fast. I have a smallish tube/fin cooler on my K5 and it has worked ok... but as soon as I install my big B&M stacked plate on my th400, the big tube/fin cooler I currently have on my tranny is going over to my steering system. Never can have too much cooling or too much fluid in the steering system.
    j
  7. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I'd caution on using radiator hose unless you've done it with a particular brand hose and know it works. Some radiator hose rubber doesn't work well with holding oil for long term.
  8. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    I've heard that a rad hose can "sweat" tranny fluid right through it. I suppose anything is possible, but I haven't noticed this on the rad hose I have on my filler neck... and its been there for 3+ years now. If it ever does leak, np... rad hoses are cheap/common.
    j
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the stuff I sold ya jek won't leak, it's rated for gas filler line. same stuff I'm putting on mine.
  10. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i took a stock big block remote can,,cut off both ends,then went to the exaust shop and had a piece of 3" exaust toob flared out on both ends to fit the caps then welded it back together..its about 10" long now seems to be working fine i also have a cooler and a filter ..the filter is the style thats inline made for tranny applications with a magnet in it..kinda looks like a fuel filter...pm me if ya want pics of it...
