Adding hydro assist steering!
Discussion in 'OffRoad Design' started by hipurr72, Apr 2, 2007.
  1. hipurr72
    hipurr72 1/2 ton status Premium Member
    Nov 21, 2002
    116
    Plain City, Utah
    Hey guys,[​IMG]
    I currently have power steering and hydro boost brakes on my 72 Blazer. What needs to be done to have my system work with hydro assist steering? Bigger pump, etc? Any fedback would be appreciated!
    Jim
  2. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I too have hydroboost and have been researching hydro steering. What I've found is that some people can run assist and hydroboost with no issues, but other can't. At best it sounds like 50/50 odds.
    The rub is that the hydro assist requires flow. Hydroboost requires pressure. What happens is that the hydroboost often restricts the flow for the hydro assist ram.
    There is a company called Vanco Power Brake Supply, vancopbs.com, that will do a "high-flow" modification to your hydrost unit. The high-flow costs $180 and they also rebuild it for $100. They will not high-flow it without rebuilding it.
    Your other options is to run 2 pumps. Willyswanter here on CK5 did it. Most of his info is on Pirate4x4, though.
    Or you could install it and take a shot you're one of the few that can get away with it.
  3. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I have also seen people cut the top of a PS pump and add a radiator hose. The length is about 8-10 inches with the neck of the PS pump at top, this allows a lot more flow which in turns add pressure. If I am wrong someone correct me.
  4. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    It doesn't add flow, only more fluid volume. Helps the system to run cooler and better with additional loads such as hydro-assist and hydroboost.
  5. Krazy Kid
    Krazy Kid 1/2 ton status
    Aug 21, 2006
    157
    Alabama
    Well, I'll put my two cents in. I have the redneck ram set-up on mine and a mile marker 10'500 hydro winch. The best thing I done WAS to run two pumps. The guys at west texas off-road said that it can be done with hydro brakes but it's better to seperate the two.
  6. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    well this should have gone under the garage section, but one thing is that the pump is the one that usually suffers due to the flow. that's probably one of the main factors of people having difficulties. you upgrade the booster, you upgrade the steering box, you use a big ram for the assist, but leave the PS pump alone...c'mon something's gotta give.
