Adding springs to leaf pack
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 1970Jimmy, Jun 4, 2002.
  1. 1970Jimmy
    1970Jimmy Registered Member
    Apr 27, 2002
    75
    Cookeville, TN
    I am considering adding a couple of leaves to each of my spring packs. Has anyone done so?? Advantages/Disadvatages??
  2. lukefalls
    lukefalls 1/2 ton status
    May 21, 2002
    163
    Fairbankks, AK
    It depends on what spring you install, but typically the spring will become stiffer. I will never get any softer. This is an advantage if you tow or haul some weight. This is a disadvantage if you want flex. Also, depending on how many leafs you install and how much arc they have, it can lift your rig as much as two to three inches, though not likely that much. Have fun
  3. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I put add-a-leaves in my front 4" springs and I seriously could not tell any difference in ride quality then with the 4" lift springs with no add-a-leaf. I had to use a bearing press to get the springs together close enough to tighten the center pin. I gained about 3/4-1 inch which brought me up to about 4 inches of lift in the front.(springs are really old)
    Evan
