Additional crossmember
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tori89k5, Feb 19, 2002.
  1. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Hey Kids.... anyone out there added an additional crossmember for frame strength ? I just put my sliders on this past sunday, and when putting weight on them I can actually watch the frame tweak. They weld straight to the the frame. Am planning on building a crossmember for just behind transfer case to tie things together. Looking for ideas before i start building.
    1990 K5 4" lift, 33" MTR's, 14FF w/ Detroit locker, D44 w/ posi, 4.10's Raptor Tranny and Velvet Rides !
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Suburbans have a 1" x 3" channel for the carrier bearing when they have a 2 piece driveshaft. just ties the top of the frame together. Although you have flex coming from the bottom part I take it? Your driveline would be your only limitation.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    The rear mounting plates for my sliders extends below the frame 2'' . I welded a piece of 2'' square tubing across the frame between the plates. I gusseted the mounting plate on the outside of the frame up to the sliders. This took care of any flex even with the entire weight of the truck resting on the sliders on the waterfall at Disney, OK
    <font color=green>Steve Frisbie</font color=green>
    <a target="_blank" href=http://www.mo-offroad.com>www.mo-offroad.com</a>
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok I just asked a ? about this "extra" brace that I have and it mounts bout where my rear driveshaft goes on the 203 and it has also a skid plate there to If you want tori I can send ya pic's tommarow after work (the brace looks stock but I don't know for sure)just let me know,I think now I will keep the "extra brace" If I put sliders on to help the "twist" factor -mike
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Your crossmember sounds stock. The factory used them to mount up the skid plate. It's just another tranny mount thrown in.
    <hr></blockquote>
  6. tori89k5
    Apr 12, 2001
    946
    Sure,..... i'd like to see some pics of it..... I may give me some better ideas. Right now my plan is a piece of 2x4 (box steel) with gusseted ends and plates that run up the sides of the frame and it will bolt on.
