Additional length in driveline due to doubler
Discussion in 'OffRoad Design' started by 79Beast, May 21, 2002.
  1. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have a SM465 and I will be putting a gen 2 doubler behind it. How much will it move my front output back? I have heard about four inches. Is this accurate?
  2. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    As far as I know, and what I am planning for with mine, is it will mose it all back 6 inches. Which will mean 6 inches less in the rear and 6 inchs more in the front.
    Ken H.
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    If you use the factory 465/203 adapter setup, you'll move the 205 back about 6". If you use the 465/208 adapter setup, you move back about 10 inches. If you already had a 465/203 in the truck, you move the front output back 3", the rear output stays in the same place.
    Hope this answers your question!
  4. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    I currently have a 465/ 205 combo....so 6". Thanks. I already have the 465/ 203 adapter, I will have to get the 203 and upgrade my 205 along with getting the actual doubler adapter.
  5. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Watson,
    This brings up a question. Do you still have the page on your site listing lengths of trannys and transfer cases? I thought you had this info on the Gen1 Doubler page with total length info. Just checking. Thanks.
  6. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    I did and don't now, I might look at putting it back up but under some more general tech info. We got away from the need for a lot of that with the GEN2, since they're all the same. The GEN1 was a bit confusing since you could mix and match a lot of different parts. Now we can just say it's 21.5" long and be done! But the general case info is handy.
