Additives for emissions
Discussion in '1982-Present GM Diesel' started by Tybee, Dec 8, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Its that time of year again, whats the best additive I could use to keep emissions down for the test?
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I thought diesel was emission's exempt?
  3. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Not here diesels have to be tested every year.
  4. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    When I lived in Palm Beach County, FL I used to have to have mine inspected and would always fail the first time. I would change the air filter (before I installed a K&N), get the oil changed (not that it helped, I just thought it would be a good time) and then it would pass.
    It always made me nervous when they put that thing on the machine and drive it at 55MPH and used a 4 inch block "just in case" it came off, the block would keep it from going through the wall /forums/images/graemlins/blush.gif
  5. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    What do they look at for emmisions? sniffer test?
  6. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Here in Sweden we use the boose that´s for gasoline so it wont freeze in the winter /forums/images/graemlins/thumb.gif
  7. RLBstein
    Jul 2, 2000
    179
    Pensacola, FL
    Yes, it is a sniffer test. They put my truck on what looks like a dyno machine with the big steel drums under the rear tires and hook up a hose to both exhaust pipes. Then they run it a different speeds for a few minutes.
  8. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    They check the amount of particulates in the exhaust.
  9. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I don't know if it would help a diesel but changing the oil will reduce the amount of HC (hydro carbons) in an emissions test.
  10. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thanks, I plan on an oil and air filter change before I take it in.
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Use the stanadyne fuel additive, and the marvel mystery oil helps too.
    By the way the diesel smog tester is Called the smoke tester. /forums/images/graemlins/grin.gif
    And yes they test mainly for particles in the exhaust.
    Luckily here in CA we don't have to worry about smogging diesels.
    When I was in the middle east they smogged the diesel twice a year, and the gasoline engines every year.
  12. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Amazing no diesel test in a state that has the toughest gas emission standards. By the way ive looked for the standyne additive and have yet to locate a place that sells it.
    That would get expensive, here it costs $50 for the test.
