Adhesive Remover
Discussion in 'The Garage' started by RLBstein, Jun 5, 2004.
  1. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I have removed the molding from my Blazer and have tried about 6 products to remove the adhesive without any luck. I have used a bumper sticker and adhesive remover with no luck,a 3M product for removing adhesives, even paint thinner and none of it has removed an ounce of this darn adhesive. Any clues of what I can use before I resort to wet sanding.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    WD-40, plus it washes off afterwards and doesn't ruin the paint.
  3. RLBstein
    Jul 2, 2000
    179
    Pensacola, FL
    After all the things i've used, its hard for me to think WD-40 will remove this stuff, but I definitely appreciate the input and will be trying it tomorrow. Thanks
  4. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yeah, i know, but thats all i use, give it a shot, you may be surprised. You may have to let it soak in a bit if it's something alittle harder. But it should work.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    goo-gone
  6. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Someone makes a little rubber wheel that you put on a drill and it "erases" the adhesive. It works very well -- I think it is made by 3M. It is my favorite way to remove adhesives.
  7. lason
    lason 1/2 ton status
    May 31, 2004
    105
    Arlington TX
    removing molding glue is a PITA and everytime I do it I end up sanding it down and spraying it with primer. I did do it one time without sanding but it was time consuming and it took about 3 cans of the 3m adhesive remover to do it. BTW that was '88 mustang I did that with and the molding is about 3 1/2" wide so there was alot of residue but the paint was real nice and I didnt want to use primer. Im about to do the same to my '86 K5.
  8. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    hey dude, like the sig! /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  9. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Okay I found it. This product is the way to go if you ask me /forums/images/graemlins/thumb.gif
  10. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    have you tried it? wish I hada seen one of those when I took the stripes and glue off my Nissan, took me a couple of weeks doing a little at a time.
  11. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Yes, I used it to take a pin stripe and the trim adhesive off my 2nd blazer and some huge graphics off a nissan pickup I had. I found it much easier and 100% more effective than the chemical adhesive removers. They cost about $20 but I think its worth it. Plus, it doesn't damage the paint /forums/images/graemlins/grin.gif
  12. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    /forums/images/graemlins/thumb.gif. that would have been a lot better. have they been out long, or just something new on the market?
  13. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    I bought mine in the summer of 2000, I don't know how long they've been around. The guy at the paint shop suggested it.
    It says not to use it on laquer paints though.
  14. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
  15. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Yup, that is the way to go!!!! I just took my moulding off, worked like the dickens for about 3 hours with chemicals...only to get about a foot of adhesive off. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    Purchased one of those wheels, broke out my drill...about an hour later the whole K5 was DONE!!!!!!!!!! /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  16. lason
    May 31, 2004
    105
    Arlington TX
    Any ideas on where to pick one of these wonders up at? Im also about to do some molding and would like to try it out.
  17. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
  18. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i used easyoff oven cleaner,but that looks way easier. /forums/images/graemlins/truck.gif
