adjustable prob valve question...
Discussion in 'The Garage' started by Thumper, Feb 9, 2003.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Hey, if I scrounge some sort of a tap from a hyd. setup, or even a small water type tap, wouldnt it work as an adjustable proportioning valve instead of spending near 90.00 CDN for one? I tried to find one in the USA when I was there 2 weeks ago and no one had heard of them nor could get one. I didnt have time to order from Summit to be delivered while I was there... ya know?
    I think they would work... cept maybe that the race Wilwood type prolly cant shut off completely right? Hmmm maybe it would be cool to be able to shut em off completely... Dunno... what do you think?
    Mike
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I hate to say it Mike...but spend the $90. It's your brakes not a fender or something trivial!!
    My 2 cents...now all you need is $89.98/forums/images/graemlins/wink.gif
    Rene
  3. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    yeah.... dont risk it for 90 bucks. Always go quality on brake parts.
  4. Grim-Reaper
    7,385
    Atlanta
    Brakes are between 600 and 1200psi. water is at about 60psi. you figure it out. Also all that would do is restrict the flow but it would still reach the same pressure once it got past the restriction. A propotiong valve controls the pressure by changing the balance of th input presure to the output presure. Spend the money and play it safe.
    Look in your local phone books for race shops. That's how I found mine and he got it for me the next day and was only about $5 more expensive with ttax then it would have been to order with shipping.
  5. Thumper
    1,582
    Alberta Canada
    Cool, point taken. I do have some smaller taps that we use on aircraft related ground handling eqpt that handles 3000 psi. But if I can get a Wilwood type one on my next trip to the USA, I will.
    Ummm maybe a stupid question, but how does the internals of the Adj valve differ from a tap? Just curious.
    Thanks for the replies.
    Mike
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    They have deceptively simple looking parts in there. Just a piston and a couple of seals. The trick is that the shape of both the piston and the seal riding on it are highly evolved. You won't get it righton the first try and I'd be really surprised if you were anywhere close by the 58th try.
    It would be a lot like making your own carb emulsion tubes, it just isn't done.
