Adjustable Vaccum Advance unit ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Executioner, May 11, 2000.
  1. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Adjustable Vaccum Advance unit ?\'s
    Getting some pinging on the freeway at light troutle, I think its the adj. vaccum advance unit on the distrb.
    Does anyone know which way to turn the adjustment on the unit to give less advance ?
    Thanks alot
  2. cityfarmer2
    cityfarmer2 Guest
    Re: Adjustable Vaccum Advance unit ?\'s
    I believe it is out I have one on mine but haven't touched it in months. But what I remember is out to decrease and only a couple of turns each try. If that doesn't fix it you need to change the spring set up. Good luck Gary...
