Adjusting a 241 question
Discussion in 'The Garage' started by sapper, Oct 27, 2006.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I have been having trouble with my 241 for quite awhile now. It will pop out of 4wd at will and is a PITA to get back in. I have been adjusting the linkage for awhile and its not acting right. I thought a common sense way to do it would be disconnect the linkage, put the lever and case in 4 low and then crank away untill the linkage met. I had some succes with that but now in 2wd the lever is not even close, I cannot find a difference in 4 hi or low it just seems to go from 2wd into 4wd. Anyone have any suggestions? TIA
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I wonder if you have a bent shift fork.....and/or bad/lost shift pads on the forks themselves? How many miles are on the case?
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    My same thoughts. Looks like you have a teardown in the near future.
