Adjusting ebrake w/ 14bolt-disks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chev4life, Jan 30, 2005.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    My ebrake recently stoped grabing and went out to try and adjust it and could only get one side to lock up with the stupid single adjust screw...is there another way to do this? Oh yeah.. I have a 14bolt w/ discs and cadi calipers. I never had a problem setting the ebrake up when I first did the swap.
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    This is going to be my next project is to finally make my E-brake work again with my rear disc. Can you PM me some pics or post some here.
  3. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Yo know, I never got any pics of the rear brake setup..I will try to shoot some tomorrow and post them.
  4. socalblazer
    socalblazer 1/2 ton status
    Mar 18, 2004
    110
    Redondo Beach, CA
    caddy caliper adjustment
    An old trick is to clamp a visegrip onto the ebrake lever then while you actuate the lever back and forth you tap on the caliper housing. 75% of the time you can knock the piston loose and get the brake to adjust up. Once you get the caliper adjusted you should make it a point to use the ebrake at least once a week to keep it adjusted. Good luck.
  5. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
