Adjusting Fan Shroud.
Discussion in 'The Garage' started by broncoman6524, May 24, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Basically whenever my truck is under flex or the stress, you can hear my fan hitting the shroud. It is sitting too high. Before i screw something up can this be adjusted or am i gonna have to cut it with a dremel.
    thnx
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Sitting too high?? or your motor mounts are too flat????
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i dunno maybe that too. LOL my dad and i checked the mounts. (Ebrake on and try to go in drive) motor didnt lift. It appears to be about 1" high.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Check your core support body mounts, thats the typical problem
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well I have been running without one for oh about..... since 1993.... but have been lugging it around.. so finally just recently.. I decided to put it back on.. now I remember why I took it off....
    my front clip came from a 454 dually... and the shroud doesnt even come close to my fan!!!!! like 4+ " away :haha:
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    This has happened to me on two trucks; I can almost guarentee that one or both of your front most body mounts are gone. The large retaining washer between the bolt head and lower cushion rusts out and then just falls out.
