Adjusting Fuel sender???
Discussion in 'The Garage' started by BXwildshot, Sep 23, 2005.
  1. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    Is there any way to adjust a fuel sender externally using a variable resistor of som sort? I'm really no good at all with electric so I need a little help with some ideas on how to do this, Thanks
    Eric
    P.S anybody got a good sending unit for a 31 gallon tank (tbi , 89 suburban) they want to part with?
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Fuel sending unit is 0-90 ohms empty-full.
  3. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    You can get a new sending unit from LMC Truck.
  4. BXwildshot
    Sep 17, 2001
    97
    Bronx , NY
    So there is no way to do it?
  5. dyeager535
    26,977
    The question is, why would you want to? I could see it if you were really anal about the gas gauge moving smoothly from full to empty on an odd sized tank.
    If it's not reading right, you just fix the problem, not band-aid it.
