adjusting hex nut on top of steering box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Dec 21, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    How much do I need to turn it to tighten it up? Should it be really hard to turn? Do I turn the nut or the allen screw inside of it? Thanks
    90K5
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    check out this site.... <a target="_blank" href=http://www.monte-list.nu/tech/boxmesh.shtml>http://www.monte-list.nu/tech/boxmesh.shtml</a>
    Good luck! [​IMG]
    -Dan
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Or read it here:
    1. use oil to lubricate threads of locknut and adjustment plug (right on top, can't miss it)
    2. raise the front end of the car so both front wheels are off the ground
    3. put the box end wrench on the locknut
    4. use allen wrench to hold the adjustment plug at the top of the box
    5. holding the allen wrench stationary, loosen the locknut with the box end wrench several turns
    6. turn the adjustment plug clockwise until snug to remove slack, then back it out 90 degrees.
    7. holding the allen wrench stationary, tighten the locknut, remove wrenches
    8. start car, run steering wheel through full rotation, checking for binding
    9. if binding, repeat steps 3-8, backing out adjustment plug slightly more
    10. lower car from jack (stands) drive car, note improvement!
    that should do it!
    -Dan
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Very carefully! A little goes a long ways.
    Good post, Dan (KRAZIE)
    <font color=blue>Wow factors
    A SBC (4" X 3.48") with 2" intake-valve at 6,000 RPMs:
    1- The piston reaches a maximum speed of 60 MPH
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    make your adjustment with the wheels straight ahead, that is where the gears fit the closest, if you adjust them when turned either way, it will be too tight in the middle.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: http://community.webshots.com/user/wdb172454
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    in step 6, the adjustment plug is the allen head screw, right?
    90K5
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Allright - got it. Worked really well too. This and the steering box brace I'm getting for Christmas should really help out.
    90K5
