ADjusting Hydrolic Clutches?
Discussion in 'The Garage' started by Pookster, Jul 14, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    How do you adjust the hydrolic clutch on a nv4500? I have to press the clutch all the way to the floor for it to disengage. Any ideas?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You don't.
    You must have a new clutch. The friction point will move up as it wears.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    sounds like it's time for a BLEEDIN" session, is the slave leaking? they usually don't do that out of the blue, there is probably something broken, or about to be broken. check carefully,clutch disk,pressure plate,and throw out bearing for wear slavecylinder and line from clutch mastercylinder, check the mastercylinder also for leaking /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    out of fluid?
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    WEll, the clutch engagmeent is kinda low- I have to press all the way down to get the clutch to dis-engage. I would like to get it to be reasonable higher, and use the forward portion of the clutch pedal.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you could lengthen the rod on the slave cylinder or move the slave backwards you could do so.
    It will move up as it wears anyway.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    add fluid
    the hydralic slave compensates for wear and pedal position will remain unchanged through out clutch life
  8. dyeager535
    26,982
    191
    Some of the aftermarket pushrods are adjustable, just look under the dash and see if the pushrod is threaded. If so, lengthen it. Had this in my truck last time.
    MJ if you check this thread again...
    I replaced my aftermarket master with a raymold or whatever master from Napa. Had rebuild kits, $10 less than a complete master.
    Anyways, pulled the piston out of both, measured the bore as best I could with some dial indicators. Both the stock and the Raymold pistons were the same diameter. Again, as best as I could tell, since the piston sealing surface of the bore is recessed.
    Bleed bleed bleed if it pedal is low and not adjustable.
    Found an interesting way to bleed the clutch as well. Of ocurse I didn't take notes, so I'm winging it here:
    Remove slave from bellhousing, cap off the pretty full reservoir. Crack bleeder, depress the pin that hits the clutch fork as far as possible (Believe I used my fingers) re-tighten the bleeder, and release the pin. I had to repeat that about 4 times and I had a proper clutch pedal.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so are you saying it is your opinion that an aftermarket rebuild kit may work on the stock Girling steel master?
    good info
    all these parts are very near or beyond the 'obsolete' designation for GM Parts
    they will be dumped eventually
  10. dyeager535
    26,982
    191
    In my opinion they could very possibly fit. At least the piston seal. I didn't notice any real wear on the stock master that I pulled from a truck a few years back, and the rebuild kits come with those and the spring...I doubt either *really* need replacing in most cases.
    I wanted to stick the new piston/seal assembly into the old master jsut to verify, but I wouldn't do that without cleaning up the old master housing, and I don't have a hone that will do it.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    we should get into the stainless sleeve business for these cylinders
    no more rust
