Adjusting Idle on TBI
Discussion in 'The Garage' started by blazer_87, Aug 18, 2004.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    I have 87 TBI. It seems to be running rich and idling high. cant find an idle adjustment. Is there one? Any advice??? thanks in advance
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    All I know is that the idle is computer controlled on TBI, you cannot manually adjust it. I think there is some sensor right in the throttle body that impacts how it idles.
  3. kd7kmp
    kd7kmp Registered Member
    Jun 2, 2004
    99
    Springivlle, Utah
    The idle on a TBI truck cannot be manually adjusted. Idle speed is controlled by the Idle Air Control (IAC) valve which is in turn controlled by the computer. Sometimes the passage used by the IAC gets gummed up. Clean the throttle body with carb cleaner. That should help.
    Kevin
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Most of the time the throttle body gasket at the base is leaking. Spray some carb cleaner around the base and check if the idle increases slightly. If it does then just replace the gasket, simple fix.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Not sure about on a stocker, but on my holley there is a throttle stop screw that allows you to adjust the idle. It on the front of the TB right in front of the trottle bracket..... According to their directions you are supposed to unhook the IAC and then set it.
  6. dyeager535
    26,980
    Instructions for setting idle are over on thirdgen.org in the tech section. IAC/TPS article IIRC
  7. blazer_87
    Oct 1, 2001
    72
    Section, Alabama
    Thanks for the info on thirdgen.org. The passenger side of the TBI has two connectors, which one is the IAC? Thanks
  8. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    the square on with four wires in it is the iac plug.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    The IAC is towards the back of the TBI on the pass side. The connector in the middle is the TPS.
