adjusting rockers
Discussion in 'The Garage' started by wraenking, Jul 8, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    so after i start my engine tomorrow, if i hear and clanking, whats the best way to go about re adjusting the rockers?
    thanks
    tom
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Remove one valve cover at a time and adjust them with it running until you hear no more clanking. Makes a bit of a mess unless you "customize" a set of valve covers.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Scan through the Advanced Previews forum and look for an article posted by Sandman. He did a pretty good writeup on the process. /forums/images/graemlins/thumb.gif
  4. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    take one valve cover off at a time you can get plastic plugs to put on the rockers so it does't spray oil all over if you don't have those you can cut cardboard out and put it up to block the oil /forums/images/graemlins/waytogo.gif
    then you fire it up and start at the front or back and back off the rocker till you can hear it rattle then you slowly tighten it up till the rattle just stops then tighten it an additional 1/2 to 3/4 turn i was told the tighter the rocker the engine will benifit more in the bottom end and the looser will beifit the top end.
    just make them all the same and if they don't rattle there good /forums/images/graemlins/thumb.gif
    good luck /forums/images/graemlins/peace.gif
