Adjusting Shift Points...
Discussion in 'The Garage' started by Wraparound, Mar 15, 2004.
  1. Wraparound
    Wraparound Registered Member
    Feb 23, 2000
    91
    Sacramento
    Ever since I had my 700r4 rebuilt it has shifted hard from 1st to 2nd, even with slow acceleration. I never really cared until I blew out my rear end while cruising up to tahoe for a wedding. Is the process of adjusting shift points manageable for a transmission-phobic. I never mess with that thing but I want to tone it down a bit. What do you guys think? /forums/images/graemlins/truck.gif
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    The part throttle shift points are set by the TV cable that attaches to the carb or throttle body.
    It is adjustable. Having more tension on the cable will shift harder and at higher rpm's. However, there is a minimum pressure required. You must have 2-4psi pressure at idle with the carb plates closed, as you give it the gas, the pressure will come up securing the clutches, if you dont have enough base pressure, you will cook the trans.
    The next question is did the rebuilder install a shift kit? If so, that could account for the harder shifts.
    The governor controls shifts at WOT.
    Heres a link on TV101
  3. Wraparound
    Feb 23, 2000
    91
    Sacramento
    They did, but at first it was extreme so they adjusted it. I was looking to lighten things up a bit more but this is one area of the truck that I do not know.
  4. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Your best bet would be to take it back to them and have them adjust it again if they can. Wouldn't want to void your warranty or anything like that.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    firm shifts are a good thing. a smooth shifting trans is a slipping trans, it will shorten the life of a trans in a hurry.
  6. Wraparound
    Feb 23, 2000
    91
    Sacramento
    Warrenty is long gone. Firm is good, banging on slow accel is bad /forums/images/graemlins/frown.gif
