Advance ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Highlander, Nov 1, 2001.
  1. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Ok I know this is most likely a stupid question but I just have to ask. I running a Edelbrock Carb and i've got two vacuum ports one is timed the other is not, at idle this one has 5in of vacuum the other one starts pulling vac. at just off idle now what I would like to know is witch port should I put my hose for the Mallory Unilite.
    Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  2. 2cocky
    2cocky Registered Member
    Oct 7, 2001
    59
    Southern Maryland
    The timed port is for the newer emisions distributers and the manafold port is for the older non-emisions distributers. At least thats what the book that came with my carb said. Most distributers hook up to the timed port. If you get it back wards you will know (trust me) It will idle great then run like [censored] soon as you hit the gas. Thats why I time the eng with the distributer disconected.It keeps you from giveing your eng all the vac. timing at idle.
    OOOPS....I THINK I JUST RAN OVER YOUR JEEP THING!!!!!
  3. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    So what your saying is put the hose on the port that has the 5in of vac?
    Eric
  4. 2cocky
    Oct 7, 2001
    59
    Southern Maryland
    What I usally do is start the eng. and put my finger over the port if it has vac at idle you will feel it pull on your finger. that port sould be pluged. the other port sould not have vac (pulling feeling on your finger) at idle. That is the port you want to hook up to.
    Now if you haven'y passed to much gas from all that finger pulling you eng should run correctly once you set the timeing.
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Like 2cocky said, you want the port that has no vacuum at idle. The reason for this is that you want the distributor to advance the timing OFF idle, not AT idle. Run the port pulling vacuum to your vapor canister or similar component that requires vacuum regardless of throttle position, or plug it if you don't have anything to run to it.
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>My Land Yacht</a>
  6. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Opps I guess I better put it back where it was haha
    thanks guys
    Eric
