advice on 91' Jimmy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Buckeye, Jun 6, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    advice on 91\' Jimmy
    Hello, I'm checking out this '91 Jimmy full size. It's loaded, no rust and has towing package. 123K. Can this rig tow a full size car (67' Chevelle) cross country on a trailer? Also, at normal driving, it runs at 210 degrees. Any advice on what to look out for is greatly appreciated. THANKS!!
    1972 K5<P ID="edit"><FONT SIZE=-1>Edited by K5Buckeye on 06/05/01 11:17 PM (server time).</FONT></P>
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Re: advice on 91\' Jimmy
    Hell yes. Make sure trailer is loaded properly and you have the right amount of tongue weight. Dont tow in Overdrive and make sure you put a tanny cooler on it.
    Have fun....
    New '90 K5 sitting in my driveway !!!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It certainly should make the trip. I'd make sure that the transmission is in good shape - Especially if it's an automatic. Before making the trip, I'd also want an auxilary transmission cooler installed. Other than that, if it's mechanically sound, it sounds good.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  4. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    If you pick it up I would buy a larger trans pan. It will hold a couple extra quarts of tranny fluid. And get the extra tranny cooler. Auto trans in these trucks like to burn up unless you the tricks to keep them from burning up. I am not saying "Don't buy the truck" I am just giving you some advise so you won't have a problem down the road. Later LittleJimmy.....
  5. Storm Trooper
    Nov 24, 2000
    4,640
    220 is a little too hot, make sure you check out the cooling system good, no oil in the radiator, fan clutch, water pump etc. Is the truck stock? Lifted etc.? It could be as simple as a thermostat. Smell the tranny fluid, does it smell burnt? Oil looks good? Make sure to check it all out before you spend your hard earned $$$$$.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
