Advice On Axle Spools
Discussion in 'The Garage' started by 4wheelin4Jesus, Apr 29, 2005.
  1. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    My buddy is telling me that i should use an axle spool. He said that they are strong, and i will not see much problems with steering, and handling on the road. Has anyone had any experience with them, good or bad?
  2. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I personally do not recommend spools in the rear axle if you plan on driving on the street. You will bark your tires on every turn and get really poor tire wear. I have a detroit in the rear and it will perform as well off road and will unlock around turns (just so long as you are not on the gas or brake). If you are installing on the front then it won't matter on the street with the hubs unlocked. Plan on having some turning upgrades to get it to work on tight trails. Unless you like getting out and unlocking one hub to make a tight turn.
    I think the best offroad setup is locker rear/ selectible locker front.
  3. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    thanks, you make a lot of sense. i appreciate it.
    God bless!
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I run spools front and rear. and yes it has it's little quirks but nothing that minding your driving manners won't fix. :D
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran a spooled rearend on the street for 3 years. It is doable but the tire wear is insane. I recently switched to a Detroit locker in the rear axle and I was shocked at how much better it acts on the street then the spool did.
    If you are building an offroad truck that sees more dirt then street then a spool is fine. But if you run the street alot you will get tired of the chirping around corners and the rapid tire wear issue.
    Offroad you will not really notice a difference. A locker and a spool are going to provide the same amount of traction. A spooled front axle can be a PITA offroad as it will make it harder to steer the truck.
    As far as steering with a spooled rear on the street your turning radius will increase a fair amount. A spool is not real user friendly on the street if you DD the truck. It can definitly be done though. Like I mentioned I did it for 3 years on the street.
    The only bonus the the spool is that they are cheap, strong, and they have a very predictable road manner. The locker can be a little quirkie with the locking and unlocking especially in the ice, snow, and rain.
    Harley
  6. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    Is your rear end 1/2 ton 3/4 ton or 1 ton?
    what size gears do you have?
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    my rear axle is a 14bff. It is the 10.5" ring gear with 4.56 gears. It is technically a 3/4 ton rear axle but is the same strength as a 1 ton rear axle.
    Harley
