Advice on removing frt Hub/Rotor
Discussion in 'The Garage' started by sandy78, Apr 24, 2005.
  1. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    One side, no problem, other side, Warn lockout won't pull out. I have the snaprings off, it just won't pass the snap ring groove in the hub. Seems to be a VERY tight fit. Any tips?
    Thanks in advance!
  2. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    some times rust and dry grease build up will do this. lots of pb blaster or other lube and keep working it till pops out.
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Sometimes the end of the axle will "mushroom" and make it hard to get the gear off. Try threading 2 bolts in 180 degrees apart into it and rock it out. If not, feel for burs on the end of the axleshaft and file them off till it comes out.
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    another trick is to spin the hub while pulling on the two screws
    good luck
