Aero tank 40 gallon tank install
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JungleBoy, Jul 30, 2001.
  1. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    I have the body off and the rear x-member out and am trying to position the tank properly. The tank is significantly deeper front to back than the stocker. Anyone installed one with body on? Is the leading edge of the tank in approximately stock position?
    Thanks in advance
    JB
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I can't comment on the stock tank, but the leading edge of my tank is 5-3/8" behind the axle tube of my 12-bolt. It's a pretty tight squeeze in there.
  3. Rooba
    Rooba Registered Member
    May 8, 2001
    28
    Portland, OR
    There's a guy on here that has a gas tank installation procedure w/ pictures. Don't know if it would help or not... I don't remember the guy's web site, so I'm posting this hoping he'll pipe up. I promise to bookmark it this time.
  4. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    Steve
    Do you have the Aerotank?
  5. Steve_Chin
    Mar 6, 2001
    1,126
    I'm not absolutely sure that it is the Aero Tank, but it is 40 gallons, and since Aero is the only one who makes a 40 gallon job, I think that it's an Aero.
  6. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    Steve
    Good to se you back. The Aero is a welded steel affair, I guess it weighs 50-60 pounds, maybe more, with flanges for mounting welded on the sides. They sent 3 bolts per side for mounting on the frame. It looks like to get the tank within 6" of the rear axle tube, those mounting flanges will have to make up on the frame kickup., not on the flat behind the rear wheel area.
    On another note, the Advance Adapters stuff showed up yesterday (I am in Peru now) and the NV4500 install will start next week.
    JB
  7. Steve_Chin
    Mar 6, 2001
    1,126
    Hmmm... Maybe it isn't an Aero after all. It is all welded steel and pretty heavy, but it mounts using some 1.25" wide steel straps. No flanges for mounting it to the frame. It does look a lot like the picture that Aero has on their web site, though (although it is kind of rusty). Anyhow, the tank itself won't go any farther back in the chassis to give any more room for the rear axle. It pretty much butts right up against the mounting point for the rear flexible brake line.
  8. CST-30
    CST-30 Registered Member
    Jul 16, 2000
    58
    St. Joseph Mo.
    I wander how many different styles aero made during their years in business,I have one but it uses long bolts that pass thru the tank and into the bed of the blazer in order to hold it in place.
    72 K-5 cst blazer 2 1/2 lift 33" bfg's
    69 custom 30 longstepside 4x4 6" lift 36" directionals
    87 K-5 stock
  9. Murph
    Murph Registered Member
    Mar 13, 2001
    40
    Seattle, WA
    I had the same set up - bolts that pass through the tank to hang from the bed. It bent the bed of the truck where the bolts went through. Also, the float of the sending unit got stuck on the inside so it never registered over 1/4 tank. I took out the tank when I went with TPI. Now I miss the range. I am thinking of cleaning it up and puting it back in.
  10. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Sorry 'bout not "piping up" sooner.
    I got the pic's on my website of the intallation of a NWMP 37 gal. tank. It's not an Aero tank. But I've heared people refer to the 37 gal tank as a "40 gallon" before.
    <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?Page=4>http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?Page=4</a>
    The 1st pic of the installation process is on page 3, everything else on page 4.
    The instructions that came with the gas tank kinda sucked. But after taking some time fitting the tank in place, I found that the straps bolt up to 4 holes that are already in the frame. Makes it pretty easy. I also had to paint the gas tank because UPS scratched it up, and the paint that comes on it is crap.
    Hope this helps.
    Anymore questions just let me know.
    Ryan
  11. Steve_Chin
    Mar 6, 2001
    1,126
    Good point, CST-30. The guy I bought my Blazer from said that the tank was dealer-installed. It is suspended from the frame by some threaded rods and the aforementioned straps and looks VERY much like the picture on Aero's web site (I can't find their URL any more, so if anyone's got it, please post so I can bookmark it).
  12. JungleBoy
    Jan 31, 2001
    243
    Houston TX
  13. CST-30
    Jul 16, 2000
    58
    St. Joseph Mo.
    Ryan B, how much more fuel does your new tank hold, by the pics I saw it looks like it is probably manufactured by the same company as your old tank, just updated a little, those side brackets were more than likely added by someone.
    Steve I've tried aero's website and dont get any pics.
    My tank can be seen in the last 5 pics of this album.
    87 K-5 stock&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by CST-30 on 09/02/01 11:30 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by CST-30 on 09/02/01 11:32 PM.</FONT></P>
  14. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    clickable
    <a target="_blank" href=http://albums.photopoint.com/j/AlbumIndex?u=1292143&amp;a=9630863>http://albums.photopoint.com/j/AlbumIndex?u=1292143&amp;a=9630863</a>
    <font color=green>BobK<font color=green>
  15. CST-30
    Jul 16, 2000
    58
    St. Joseph Mo.
    Thanks Bobk, I couldnt figure out how to do that.
    87 K-5 stock
  16. Ryan B.
    Jul 18, 2001
    5,693
    CA
    CST-30
    I'm not sure who made my first tank. It held around 25 gallons it seemed like, but the sending unit probally hid 10 gallons. (I never ran it so low it was out of gas.)
    So the first tank was probally about a 35 gallon tank.
    The new Tank from Northwest Metal Products hold 37 gal.
    If you look close in the pic's there is a slightly different shape between the two gas tanks.
  17. Steve_Chin
    Mar 6, 2001
    1,126
    CST-30, it appears that they changed their site since I last looked. The last time I looked, the Chevy page had a picture of a tank and set of straps that looked almost exactly like my tank and straps (except they were pretty and mine are UGLY). I'm pretty sure my tank is an Aero because it holds 40 gallons and doesn't look a thing like my buddy's NWMP 37 gallon tank.
