after lift steering correction
Discussion in 'The Garage' started by mostwanted, May 30, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I will be lifting my K5 next month via 52"/54"rear. I would like to be doing a crossover, but I cannot afford it for a couple more months. So which way would be better for steering correction? Drop pittman arm, or raised steering link?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    with the 52" front swap you have to do a crossover steering setup as it pushes the front axle forward
  3. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    yes, but I plan to use a zero rate to move it back if that is a problem. Plus, can't I just modify the link that has all the threads on it? Draglink?
  4. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    just save the money for the x-over...why are you going to do work that you don't have to do...i just paid 675 for my HySteer from Sky Manufacturing...their x-over is about 3** something...
  5. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    because I can put a arm on for less than $100. Upgrade later, then sell it. The lift should cost me about $500. Then tires are going to cost around $900. That will about take care of my budget for a few months.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dude steering is far more important than new tires. i drove around with small tires for a long time...who cares. get everything else squared away before you do the tires.
  7. RGV72BLAZER
    Jan 23, 2006
    2,425
    i agree...but if you want to comprise your safey & that of others then go right ahead...how about finding some less expensive tires on line that are used, that way you can work in a x-over kit with your budget...i'm sure you can find a less expensive x-over kit than i mentioned above...i found my 44" boggers on line that i got for 1400, used {about 98.5% tread}, & brand new woulda run me at least 1900 + shipping...
