After two years, it's rollin'
Discussion in 'The Garage' started by Rednekjimmy86, Dec 7, 2006.
  1. Rednekjimmy86
    Rednekjimmy86 Registered Member
    Dec 6, 2006
    16
    Parkton, NC
    Hey everyone, I finally got my truck running after sitting for two years now! I replaced a bunch of seals on the motor, installed a headliner, rebuilt the carb, added some 33x12.50 BFGoodrich T/As - they rub a little when turning a hard right, and dual straight pipes. Well, I was getting ready to drive it up to my college last weekend and I noticed it had some holes in the radiator! This thing is going to nickel and dime me to death!
    It's finally running really good and strong, but I didn't realize how much gas it sucks down. But other then that it's great! I guess it cost to look good!
    What i wanted to know is with my tires rubbing, do yall think I need to cut it or beat it back with a hammer or not worry about it?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    You have a few options.
    1. A small 2" lift kit can be had cheap and will fix the rubbing issue.
    2. You can trim the fenders and Steve has a good article in the Technical Articles section - use the navigation drop down menu to find it.
    3. You could beat it with a hammer.
    Just remember that everytime you increase the tire size you have to compensate somewhere else. If you are on the trail or hit a pothole on the road your fender will drop down on carve a groove in your tire. Over time they get torn up a bit. In the end it depends on what your willing to accept.
  3. Rednekjimmy86
    Dec 6, 2006
    16
    Parkton, NC
    I hate the idea of cutting into the body, I don't want to mess it up. I also really do not want to spend anymore money then I have to on it, I'm trying to save up for some body work.
    So right now I am leaning towards trying to beating it with a hammer and hopefully it will not rub anymore!
  4. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    ok if you beat it with a hammer it is just going to cost you more $$$ when you get the body work done to it.
    you can pick up a pair of 2 inch add a-leaf for the front for $70 and 2 inch blocks for $50. and you wont have a problem and it will look better
