Afterburner and Doug Thorley Headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA Bogger, Mar 2, 2001.
  1. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    I've been pricing headers and came up with two for about the same price. Afterburners with ceramic coating and Doug Thorley with the nickel plating that will probably wear of when you apply a little heat!!!!!!!!!! What everyone running out there? Are the Doug Header worth the money????
    Eat More Mud!!!!!!
  2. K10
    K10 Registered Member
    Feb 18, 2001
    52
    Rexburg, Idaho
    I bought a set of Afterburner header and they had bends and dents all over in them. I sent them back and got a set of Hooker headers.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Supposedly the Afterburners give a lot of low end torque because of the tri-y design, and more horsepower up higher. I will be going to them soon, I was considering the Thorleys, but the ones I saw were a lot more expensive. I'd like to have more power everywhere if possible, and those headers seem like they will work well for how I drive my truck.
    90K5
  4. Whassup
    Whassup 1/2 ton status
    Feb 2, 2001
    140
    Wyoming, USA
    I use Thorleys, I'm quite happy with their performance, and the plating on mine hasn't came off even slightly.
    "There's NO replacement for displacement!"
  5. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    I'm running Thorley's on my truck and love them! They did fade and lose their color, but you can jet-coat them if you want to prevent that - i definitely think they are worth the money - plus they have an awesome, awesome warranty
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm running Afterburners with ceramic coating. The coating is fine after more than a year. Installation was very easy and they made a perfect fit.
    Performance is great. I didn't lose any low-end torque as other headers, and gained a lot. When I open the hood, I don't feel a lot of heat since the ceramic coating keeps the heat inside.
    I also thought mine were bent when I bought them, but then I realized those bends were made on purpose to clear spark-plug installation.
    Bottom line is I'm very happy with them and feel they are great for the price I paid. Thorleys were much more expensive and were chromed, which is not as good as ceramic coating for this application.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  7. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm probably going with the afterburners pretty soon. I've heard nothing but good things about them. My dad seems convinced that you need to take the engine out to install them unless you want to work on it all day. How easy was the install?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I've never heard a bad word said about Doug Thorley Tri-Y headers. A friend of a friend has an older RV with a 454; he installed the Thorley headers and picked up 2 MPG (BIG change for an RV) and lots more power on the butt-dyno. Thorleys are made with heavy-gauge tubing and massive flanges, which means they'll last longer than bargain headers. You get what you pay for... Which is why I'll be saving money for them.
    [​IMG] Semper Maintenance!
  9. 89 Blazzer
    89 Blazzer Registered Member
    Aug 9, 2000
    29
    I put painted Afterburners on my 89. They slid in without much problem. I had to wiggle them around a little. If you have a lift they will go much easier because I think I had to take the starter off. The clearance gained underneath helped as far as plug installation and and the back passenger side bolts. I have not noticed a big power gain, but I have 160,000 on it and could use a fresh 350. I also went with copper gaskets and have not had a leak yet after 1 1/2 years. I haven't even re-tightened them yet. I did use some header paint from Eastwood. They looked great until the winter. I think the road salt did a number on the coating because the headers are only rusty on the bottom part that is exposed to the elements.
  10. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    I just got some Thorley Tri-Y headers for $350 from www.summitracing.com. It was hard to cough up the cash, but I was replacing the Hedman headers which only lasted about 4 yrs[​IMG]. I don't recommend Hedman! The Thorleys came with a good gasket and quality construction. Initial performance is awesome, but it's only been 8 days. The triple plated chrome discolored a little, but I don't care about looks, just performance and durability. You can wipe them down with isopropyl alcohol (rubbing alcohol) if you want them to discolor uniformly.
  11. jarheadk5
    Mar 6, 2000
    4,389
    PA
    When I get my Thorleys, I'm considering asking them if they can send them un-chromed so I can get them HPC or Jet-Hot coated. Not sure how that will go over, though...
  12. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I can't speak for Thorleys on the Blazer, but I do have them on my Nissan. They where the best after-market product I have ever installed. The coating has faded with the heat, but no rust and they still look great. I would highly recamend the Thorleys.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  13. Blazer79
    1,816
    Installation was very easy. I didn't even had to remove the starter. I chose Afterburners because they came ceramic coated and still were cheaper than Thorleys. Low-end torque is great and I finally discovered what it feels to have a high-end torque.
    I highly recommend them.
