Aftermarket 14 Bolt shafts
Discussion in 'The Garage' started by sled_dog, Nov 1, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What options are there? Superior and Moser as far as I know. Not certain on Moser shafts though. Don't respond with "why?" Reasoning is actually wondering if I could get some stronger shafts then have them gun drilled to reduce weight a bit. Anyone make a higher spline shaft for the 14 bolt?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think Moser will make you anything you want for a price. I am sure Superior will too. I have seen some weird custom gun drilled stuff on Mosers site in the past. I don't think the amount of money you will spend on the custom axles to save the little amount is probably going to be high. There is probably better places to try and loose weight for less money.
    Harley
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    The only numbers I've seen on shafts previouslly were 17 before drilling and 9 after. 16 pounds is 16 pounds.
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Jack from CTM can do some trick stuff to 14 bolts. One option is 300M double splined shafts with his drive flanges and caps. You'll have to give him a call to find out anything else.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the new t-locker for the 14 bolt will supposedly have the option of letting you run 30, 35, or 40 spline shafts. only bad thing is the actuator is mounted on the diff cover /forums/images/graemlins/frown.gif
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I'm going to say Superior. My reason is I read here (I think it was the ORD forum) that they "roll" their splines as opposed to cutting them. My understanding is the rolling process makes stronger splines.
    Please be sure to post an update with what and why you bought. I'll be buying shafts after the first of the year so I'm interested to know your results.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah well ORD sells Superior shafts, so yeah.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    From what I remember Moser does make them.
  9. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    if you're in the "save weight at ANY price" mode, the only solution is to call Sandy Cone and get some gun-drilled double-splined 300M shafts. They are as good as it gets.
    j
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm wondering if you're needing to save weight that bad, why you're running a 14 bolt in the first place?
  11. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    not to get off subject but why after market shafts for a 14bff? just saving weight, which I would kinda understand, but if its for strength, why? how many 14bff shafts have you seen break
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am all for saving weight, but I would starter higher up than the axles first.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, that too. /forums/images/graemlins/thumb.gif
  14. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Exactly, if your mega into saving weight, why even run a 14FF to start with. The whole point is its the cheapest tough as nails axle, not that its the lightest.
    If you want to save weight, and retain strength, a FF D60 and 35 or even 40 spline axles would be your best bet. You have to adress the spindle size to clear this size shaft, but if your doing it to just save weight...might as well do it right the first time.
    If al you want to do is get stronger 14FF shafts and don't care about weight, then I think its a valid argument.
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Weight off the axles (unsprung weight) is HUGE in terms of handling and ride comfort. A small weight loss can make a huge difference. That being said, I'd look at other less spendy weight loss options first.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I was thinking about the spindle issue. Thought was 14 bolt spindles on the 60 housing with 4 spline shafts. I ahd been thinking Dana 60 the spinddle issue was the big obstacle.
