aftermarket axles
Discussion in 'The Garage' started by gmcjimmy4x4, Aug 27, 2006.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    What are your guys opinion of aftermarket axles for the 10 bolt. I just returned from a rough trip. I broke both front axles and a lift block which caused rear u joint failure.( thank god for the winch) After getting a new u joint hiked 2 miles into the trail, We were able to slowly get out to pavement with 2 wheel drive and alot of winching. But still had to have it towed home. Id like to swith to d60 but i already have invested so much into the 10 bolt. ARB, 8Lug, Hubs. those d60's are so expensive , thought i might try the hardend aftermarkets first.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you are set on staying with a 10 bolt and dont mind spending money on it through some cromos and CTMs in it and I bet it would be good. What size tire are you running? Also get rid of the block in the rear and then you wont have to worry about breaking them:D .
    Ira
  3. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    im running 37 x-terains and the truck will not be moving again untill i get a new set of rear leafs for it.Inever want to be stuck like that again.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    says he's running 37s in his profile, chromos and CTMs he'd probably be ok.
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yep chromos, CTMs and a shackle flip sounds like all you need.
  6. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    why the shackle flip
  7. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    better flex, better ride, gets rid of blocks.
