Aftermarket door problems!
Discussion in 'The Body Shop' started by Jew Pimpin, May 10, 2005.
  1. Jew Pimpin
    Jew Pimpin Registered Member
    Apr 12, 2005
    69
    Richmond, VA
    My latch and lock assembly just bound up so the doors would not lock or unlock while latched. LMC doors. They worked fine for about 2 weeks then just stopped. I got new latches from GM but the same problem happened.
  2. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    sounds like it needs a striker adjustment..
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Before I removed the doors...mine got stuck from time to time...
    I couldn't get out of the truck with out rolling the window down...
    and pushing the outside door handle button...
    On some aftermarket doors..
    The location of the inside door handle...can be off enough...
    that the linkage won't left latch assembly hit HOME like it needs to be..
    Also...check the linkage...oil the return spring on the latch mechanism...
    they rust up...casuing problems too.
    Good Luck!!! :cool1:
  4. Jew Pimpin
    Apr 12, 2005
    69
    Richmond, VA
    Thanks, bought new latch assemblys from Chevy yesterday and still no luck. Went to my local Chevy dealer this AM and they are gonna try to figure it out for me. Tired of messing w/ it and don't want to beat in my new doors.
  5. Jew Pimpin
    Apr 12, 2005
    69
    Richmond, VA
    Problem Solved
    It had nothing to do with the doors, the aftermarket outer door handles were messed up where the rod connected. GM outer door handles problem solved.
  6. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i had the same problem.
    i switch the old mechanics into the new chrome of the aftermarket handles.
    it works fine now.
  7. nmud2deep
    nmud2deep Registered Member
    Apr 23, 2003
    63
    georgia
    i have the same problem not with the doors i have and they are made of thin sheet metal and my door panels dont even match up to the factory holes
