aftermarket fuel gage and sender set up?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grunt11b40x, Oct 6, 2003.
  1. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    does anyone know of where or who makes a aftermarket fuel gage and sender set up, my stock one is shot and i can't get it to work. /forums/images/graemlins/confused.gif i have tried to run the wire from the tank to the harness and the gage is still dead unless i just did not have the right wire under the dash hooked up. anyone have any clues which one it may be? 75 k5 /forums/images/graemlins/1zhelp.gif
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Autometer makes the set up, BUT give us more detail. Where is the needle? What happened before this happened? Any other pertenant info you can give us?
  3. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    On the back of the gauge cluster there is a bulkhead connector, the fuel gauge takes 3 wires, Pink is the sending unit wire, Pink with black tracer is 12v postive ignition to gauges, Black is ground
