aftermarket gas gauge????
Discussion in 'The Garage' started by the fall guy, Feb 24, 2005.
  1. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    Is there someplace I can get a aftermarket gas gauge for my 85 k5 or do I have to go to a scrap yard....the gm dealer told me that they don't sell or make them anymore from gm.
    Nick
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you can get them through any place that sells aftermarket guages. you'll need a 0-90 ohm guage.
  3. orangeGMC
    orangeGMC 1/2 ton status
    Dec 26, 2004
    184
    Connecticut
    Would that be the same guage for a 78 and an 81?
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Yes. All Chevy gauges are 0-90ohm and should all be the same form 73-87.
  5. dyeager535
    26,975
    The gauge will work, but I believe the script on the gauge face and the needle won't match the other gauges. I thought '79 or '80 was the changeover to the newer gauge script. There were changes even after that, but not to the extent of needle color and color of the writing.
  6. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    I have dual tanks and wanted to have dual guages so I don't have to switch tanks just to see how much fuel I got.
  7. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    Yes, I was wondering the same thing, is it possible to wire up a gauge to each tank then remove the stock gauge and use the empty space for a 5" tach.
