Aftermarket Gauges
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlackDog714, Feb 2, 2003.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    I am thinking of replacing my gauges with AutoMeter gauges. Do any of you have pics of your replacement gauges?
    I was thinking of volt, oil pressure, temp and tranny temp for the smaller gauges and the 120 MPH and 6000 RPM gauges for the big gauges.
    How hard is it to make them look right and not all hacked up?
  2. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    sorry i don't have any pics. but i used autometer , i think there called super comp gauges, at 2 5/8" dia.
    i took out the stock dash and useing a small router with a 1/4" bit, removed the plastic that covers the 4 stock small left hand gauges. making a 2 5/8" hole for the autometer gauge to slide into. a hole saw might work to if you hold things steady.
    it really looks good and makes for and easy fit of those gauges...
  3. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Did you replace your speedo? My speedo is jumping around and the needle is bent.
    Oh yeah, I forgot about the fuel gauge!
    I guess I could dump the tranny temp and put the fuel gauge there.
    Anyone with pics?
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Like this?
    [​IMG] [​IMG]
    Bill
  5. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Well as cool as that is, I was more looking for stock replacements. The open dash with no glovebox doesnt hold up to well on the street.
  6. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Uh Open your eyes! There is a glove box there on the passenger side. A fully functional dash with heater\defroster controls, lights, battery manager. And it will out last any replacement dash pads! And further more this is not an open dash, it has defrsoter outlets on top, I just ommited the vents in front as I never used them before!
    Bill
  7. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Uhhh, ok eyes open now /forums/images/graemlins/eek.gif. LOL Ok, so you have a glovebox, however, I am still looking for "stock" replacements.
    Besides, I have NO metal working skills. /forums/images/graemlins/frown.gif
  8. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Just do a search you should find the post that replaces all the stock guages with aftermarket one in the stock bezel!
    Bill
  9. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
  10. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Does this help?
  11. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Thats exactly what I was looking for Rocky! Thanks!
  12. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    My set up is very similar to sparky's. All the gauges are easily in view.
  13. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Sparky, where did you get that bezel?
  14. Sparky87k5
    May 6, 2001
    726
    The bezel is 1/8" alluminum cut into 3 seperate pieces. Mounts for gages are autometer angle mounts for the 2 1/8" gages and 3" PVC pipe for tach and speedo cut at angles too.
  15. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    Tweetysuarus, that is a SEXY dash!!!!! i have been thinking about doing my dash with one big sheet of aluminium. im gonna make a list of how-too questions and send them your way if you dont mind.
  16. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    I noticed that you put a small gauge in between the speedo and the tach. What gauges do you have? I like the idea, it would be a nice place for a tranny temp or an air pressure gauge.
    /forums/images/graemlins/thumb.gif
  17. Sparky87k5
    May 6, 2001
    726
    Both are good choices but sense the 4 gages to the left are volts, water temp, oil temp, & oil pressure, I put the fuel gage between the tach and speedo. I also installed low oil pressure light (red) and high water temp light (amber) in the 4 gage area.
  18. ford_assassin
    ford_assassin 1/2 ton status
    Nov 8, 2003
    101
    Bakersfield, Ca.
    Does this help?
    I wanna see the pic!!!
