aftermarket guages/factory dash
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bodacious, Feb 18, 2007.
  1. bodacious
    bodacious 1/2 ton status
    Dec 29, 2005
    296
    Quitman, Mississippi
    How hard is it to install aftermarket guages in the factory locations in an 83 dash? I also think I saw a link to a custom dash with the guages already installed on here. Pics would be appreciated. Thanks for the help.:waytogo:
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Install is easy. To get the proper angle so they face the driver is the hard part.
  3. 76_gmc
    76_gmc Registered Member
    Feb 19, 2007
    30
    Enterprise, AL
    let me know
    bodacious...you get good info on this, let me know. I have an 84 and want to get rid of the look and redo the dash/console/bezel and gauges completely.
  4. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
  5. Jrgunn5150
    Jrgunn5150 1/2 ton status
    Nov 26, 2005
    232
    Cleveland, Oh
    Doa search there are two really good threads on the subject.
  6. bodacious
    Dec 29, 2005
    296
    :eek1: :eek: :doah: Covans Classic is HIGH $$$$$. I just don't see that much in the products they have.:eek1: :eek: :doah:
  7. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Ryoken points out the problems with the Covan as well. Not for me!:rolleyes:
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Yup, either Jeremy or Sweetk30 did the same thing with a dremel and 10 minutes...
    I have to find the pic of THE one factory setup i've seen with the gauges done at a nice angle... its a 2 wd truck.. i'll hunt for it...
  9. rivermtnman
    rivermtnman 1/2 ton status
    Nov 7, 2003
    102
    Lebanon, VA
    Here's a pic I saved from a forum in here I once saw...
  10. 76_gmc
    Feb 19, 2007
    30
    Enterprise, AL
    not bad, and probably saved a few pennies that way too.
  11. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    yup, thats the one... It's the only one i've seen with angle correction....
  12. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    heres mine.. no angle correction... i dont drive her oin the street much soo didnt feel that it needed done.. i can see the gauges just fine....i used a trenz billet alumin piece that is designed too bolt on over ur existing dash...
  13. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    heres mine, no angle correction for the 2 main guages, but i only stare at all the small guages anyways.
  14. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    So if you got a piece of aluminum and copied that bolt on one. How thick should the aluminum need to be to cut the holes at the correct angle for mounting? 1/4" - 5/16" - 3/8" ? I've thought about getting flat stock to make a solid panel, either by making the two bends or possibly 3 flat pieces and then take it somewhere to cut the angled holes for me.
  15. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    why not just make up an angled piece of tube (wedge shaped) and put it between the front of the guage and the sheet of metal
    you would be able to adjust the angle by varying the wedge.
  16. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
  17. Jrgunn5150
    Nov 26, 2005
    232
    Cleveland, Oh
    So does SUmmit.
  18. BDAMNRZ
    BDAMNRZ 1/2 ton status
    Aug 9, 2006
    124
    Chesterfield, VA
    gauge panel
    Here are some pics of mine. I used the angle rings on all of them. It makes them a lot easier to see. I cutout the back of the change tray. Got some plastic I found in the garage and covered the opening. Then cut the hole and used angle rings for the tranny temp and fuel pressure.
  19. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    doesn't that shift light blind you?
  20. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    I usually have a cover on that. Its not blinding in the day cause when it goes off I'm usually not looking right at it anyway. At night it will.
