Aftermarket heater motor?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MuddyMudSkipper, Mar 23, 2002.
  1. MuddyMudSkipper
    MuddyMudSkipper Registered Member
    Mar 7, 2002
    49
    CA
    My heater motor doesn't blow much air. Anyone know of an available upgrade so I can actually defrost my windshield?
    Jeff
  2. 69jimmyhendrix
    69jimmyhendrix Registered Member
    Nov 30, 2001
    8
    Great question. I have the same problem & wonder if that is just how they come from the factory or if they just degrade. Am having a similar problem with my wiper blade motor too. Hopefully someone in the know will contribute, good luck.....
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    On mine you had to push the slider all the way over and then press hard so it would go the last little bit. it never really turns on until you get to the last half inch. probably just a new fan motor would do it. Once its on it b;lows pretty good.
    sorry i couldnt help more
    nathan
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Is the moter that is in there old .
    If so then just get a new one and your set.You could also try cleaning the connections on the motor's electrical just my 2 cents
