Aftermarket Steering Box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Jun 25, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Does anyone know of a replacemnt steering box. I saw the AGR ones, kinda expensive, just wondering if they are the only choice for aftermarket? Who else sells one?
    Is Napa the best place to get a stock replacement?
    <A target="_blank" HREF=http://www.geocities.com/baja/5099>http://www.geocities.com/baja/5099</A>
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I said it once, I'll say it again.
    Stay away from AGR!!!
    Boss
    ps, I'm not sure who else is out there though. Stock replacement of boneyard is the way to go :) Save some dough.
    Boss
    89' 1 TON of FUN K5
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Why do you need a new one?
    If it's because you don't have one or are looking to do crossover steering and need a 2WD box, go to the local salvage yard.
    If it's because your "box is loose".....(no comments), adjust it with the allen head and lock nut (1/4 turn increments)
    If it's because it's leaking, reseal it.
    If you didn't built it yourself, how can you call it yours.......?
  4. Burt4x4
    6,854
    Tell me Boss?? I didn't every hear/read anyone say that about AGR!
    What happen?
    I probly will just get a stock replacement but I just wanted to explore all my options!
  5. Burt4x4
    6,854
    Yes cuz it started leaking. I just upgraded my front D44 with 4.09s and a Power-Lock + Warn axels and all the other goodies. I drove on the pavement in 4x to brake in my R&P sets. Now all of a sudden allot of PS fluid is leaking out of the input shaft seal. Yes I could just reseal it but sence the box is original 1972 stuff I am thinking it's time to retire that box and get a new one while I'm taking it off anyway......
  6. Leadfoot
    Nov 28, 2000
    3,112
    Make sure to get the correct box or you will have to change the lines that go to the pump. Which actually doesn't matter because the lines should be replaced anyway, but you will have to know which type to get (O-ring seal or flare seal)
  7. Boss
    2,550
    Maryland
    Burt,
    Ok, first, spendy for one thing...way over priced....like $320 for the supposedly "better than stock" steering box. And they said you don't notice any difference unless you get their supposedly "better than stock" PS pump. Which is about $130 or so. Supposedly, they flow better, who knows.
    Anyhow, my problem with them is that My AGR Ram kit came with mixed up parts. I called, and they said they'll overnight me an adapter to make the mixed stuff work....no biggie I thought.
    Well, next day, nothing. I called, they said they forgot. I complained, and they said they'll send next day again. No biggie I thought. Next day, nothing again...I called, they said, they forgot AGAIN!!!!! F*ck them!!
    Ok, they finally got it out the day after. I put it on, things are ok, nope!! the ram leaks, so I had to take it off and send it back. They said, it will take em 2 hours to fix after they recieve. NOPE, took them 5 days before they sent it back.
    While I was driving 2weeks without the RAM, The steering was not as good as I thought. I was fighting the wheel just to turn. It felt like no Power steering at really slow turns, or while trying turn.
    On top of things, my box runs supppeerrrrr hot!! I'm talking burn your hand off hot. I have a cooler too.
    Boss
    89' 1 TON of FUN K5
  8. Burt4x4
    6,854
    Wow that sucks!
    I will probly just get the Napa rebuilt one and call it a day........I don't feel like dropin 500 bills by the time I'm done replaceing everything.....
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I dont know if Napas are the best but it was only $189.Been running mine for a little while now and I got no complaints.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    How hard are they to rebuild? Mine leaks a lot.
    90K5
  11. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, really. Your saving money for those new SSr's.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  12. Leadfoot
    Nov 28, 2000
    3,112
    Not hard at all, PM me and let me know where yours is leaking.
