aftermarket steering wheel+
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jun 21, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    whats needed to do the switch?
    some kind of adapter...?
    I am clueless here
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Typically aftermarket steering wheels are a universal fit, so you'll need an adapter for the specific vehicle.
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i've got a grant steering wheel. just look up your vehicle in their book and it will tell you what mounting kit to use.
  4. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    I bought a Grant classic 3-spoke steering wheel with black foam grip and blue bowtie center cap from LMC truck. I also bought the adapter from them as well for $20, then later on found the same adapter at Autozone for half the price. The part number for the installation kit is 38-1182 and you can order straight from the LMC website (LMCtruck.com). Keep in mind the kit is only for Grant steering wheels. Hope this answers your question.
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    P.S. I got mine from AutoZone. I think it was just under $50 for the wheel and the installation kit.
  6. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    You will need a steering wheel puller also. You should be able to borrow from autozone for free. Pretty easy to do.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have an adapter sitting in my tool box....came with a Grant I bought..
  8. tecton
    Dec 1, 2002
    1,553
    WV
    i think im at the impass where i need the steering wheel puller, lol
    autozone wants 15$ to rent this
    anyway to improvise a way around this?
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    im an honest person so i let them take 20$ away from me.
    They give me a reciept and i find the steering wheel i want 39.99. I go to the register and the lady rings me up. She tells me "that will be 1 penny" i think for a second and hand her the money.
    I guess she didnt take the second seat cover off the return...either way, i got me a free steering wheel
    im an honest person
    /forums/images/graemlins/grin.gif
  10. tecton
    Dec 1, 2002
    1,553
    WV
    /forums/images/graemlins/wink.gif
  11. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    My orginal wheel was a small diameter Grant. I switched it to a bigger wheel. 'Gave it a good yank, it came off and popped myself in the nose /forums/images/graemlins/blush.gif Maybe your stock wheel has been removed before and can be removed without a puller,,, watch your nose /forums/images/graemlins/grin.gif
  12. tecton
    Dec 1, 2002
    1,553
    WV
    i found a puller in the tool box...dad says its a gear puller but it might still work...
    if anyone here could find or draw a diagram of what exactly has to happen in order for this thing to come off it would help greatly
  13. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    now what about the 88-up style chevy steering wheels? do they reguire any speacial adapters? i would guess not cuase they put them in the 89-91 blazers and subs and they have the same steering columns..but i could be wrong.. /forums/images/graemlins/confused.gif cause i want to put one of them in my 86 chevy
  14. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    in the past i've threaded the nut back on the shaft so it's flush with the top of the shaft, stuck a big flat screwdriver or small pry bar behind the steering wheel and pushed against the wheel with it, and then hit the nut with a hammer a few times and they popped right off.
    also, that $15 that autozone wants for the rental will be given back to you when you return the tool.
  15. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    go get a haynes repair manual and it tells you what to do in there.
  16. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have a puller now, but I have removed plenty of steering wheels by just hitting the steering wheel from behind with my hands from both sides alternating, creating a vibration that usually frees it.
    Also one time tried the other way around having the nut flush with the shaft, pushing from under with my hand and giving it a waack on the nut like someone described above /forums/images/graemlins/thumb.gif
    I would buy the puller for $9 Harbor Freight
